Hi,
I've been dubbing VHS tapes and Laserdiscs to dvd using a dvd recorder. They play back fine on my CRT but when I watch them on LCD there are lots of lines on screen during movement. I'm assuming this is interlacing? How can I remove the lines so that the picture appears smooth and has no line-artifacts? Is it recommendable to do so (I read something about losing picture quality)? Also, what programes are best and easiest to deinterlace with?
I've included a picture to illustrate what I'm seeing.
Go easy on me here, cause I'm totally new to this!
ps. I'm working in both Pal and NTSC
Dave.
Results 1 to 9 of 9
A software dvd player should be able to deinterlace it when you play it. What are you playing with now?
Do normal dvd players deinterlace? I haven't got an LCD tv to try it on.
The LCD TV will do it.Originally Posted by dave_van_dammeJohn Miller
Progressive DVD players will deinterlace while in progressive mode. The quality of the deinterlace needs to be compared to the deinterlacer in the progressive TV. Try it both waysOriginally Posted by dave_van_damme
Set DVD player to 480i/1080i --> Progressive TV deinterlaces.
Set DVD player to 480p/720p/1080p --> DVD player deinterlaces and passes 480p/59.94 or 720p/59.94 to the progressive TV over component. 1080p setting would force a 24p conversion (quality hit)
Edit for PAL
Set DVD player to 576i/1080i --> Progressive TV deinterlaces.
Set DVD player to 576p/720p/1080p --> DVD player deinterlaces and passes 576p/50 or 720p/50 to the progressive TV over component. 1080p setting may force a 24p conversion (quality hit)Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
1. So they can compress more (e.g. divx,xvid,h.264)Originally Posted by dave_van_damme
2. For web distribution (e.g. flash, wmv)Recommends: Kiva.org - Loans that change lives.
Blackmagic Intensity Pro - NTSC Captured File Not Recognised at Interlaced?
By kauri in forum Capturing and VCRReplies: 22Last Post: 22nd Nov 2011, 12:21 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
How to know if a video is interlaced?
By JLGUT in forum EditingReplies: 9Last Post: 20th Mar 2009, 15:40 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03 -
How can I tell if a video is interlaced?
By cheerful in forum Newbie / General discussionsReplies: 10Last Post: 18th Jul 2007, 21:56
