Hey everyone
I've been using nero for quite a few years now, and I was looking into switching sides for a while. Any recommendations for something to replace it. All I really use it for is burning data to dvd/ cd's and on occasion make some video dvd's. I basically need something with the same basic functions of nero, but not as bloated as it.
Thanks in advance.
Results 1 to 11 of 11
For general burning, Imgburn.
It won't allow you to make DVD-video discs directly, though, but it'll burn a properly-compatible DVD from a VIDEO_TS folder generated from another source.
If cameras add ten pounds, why would people want to eat them? -
for 90% of my burning needs i use cdburnerXP. It's small and free and does most crap you need to do. as far as DVD it will burn the VIDEO_TS to a dvd and play it. but chek it out and let me know what u think
if all else fails read the manual -
Originally Posted by dannyboy48888
as well since I also use CDBURNER XP for burning data.
I use Imgburn for burning everything except audio CDs. It burns data just a well as it burns DVD Video.
For audio CDs I use Prassi ONES.Read my blog here.
Imgburn won't create DVD video discs from assorted clips, though, which seems to be what the OP wants. Frankly, you're probably better off using FAVC or DVD Flick to create a DVD from the clips, then using Imgburn to burn, as opposed to hoping for an all-in-one. There really isn't a single program that can take the place of Nero in that regard (since you're looking for something that'll not only create data discs, but DVD video discs as well (and possibly other disc formats).)
VCR replacement
By yuhr in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 22:10 -
Looking for a replacement
By Peacedog in forum DVD & Blu-ray RecordersReplies: 7Last Post: 2nd May 2009, 19:13 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
Nero Replacement for Audio and Data burning
By mlong30 in forum AudioReplies: 6Last Post: 1st Jul 2008, 12:55 -
Need a replacement for Nero Recode...
By jemenake in forum Video ConversionReplies: 1Last Post: 8th May 2008, 18:13
