I'm trying to get my head around why ffdshow refuses to play .m4v files. I've enabled the H.264 codec (on by default), I've used the "fix all problems" button on Filmerit, and I've even bumped up the Merit of ffdshow to prefered. Nothing seems to get the files recognized by WMP11. It's not even attempting to load ffdshow when it tries to play them. I've set up ffdshow to prompt whenever an application tries to load an ffdshow filter, and I get no popup on .m4v files.
Now the wierd part is MPEG2 (DVDs) work without a hitch. Can't make heads or tails of it.
Does anyone know how to delete all codecs and start from scratch without reformatting windows?
-Dan
Dan <11011011>
Yeah. Do you have Haali Media Splitter installed? If not, I'd certainly recommend it.
Does WMP see the video differently if you change the extension from .m4v to .mp4?
You probably already have ffdshow set to allow WMP, so it's not going to generate that popup.If cameras add ten pounds, why would people want to eat them?
MPC-HC unable to playback M4V files
By cheerful in forum Software PlayingReplies: 8Last Post: 6th Aug 2011, 23:02 -
No playback of VOB files in WMP11 (yes i have the codecs)
By raffie in forum Software PlayingReplies: 21Last Post: 15th Mar 2009, 08:31 -
WMP10 and WMP11 commercial DVD playback Solved
By gll99 in forum Software PlayingReplies: 4Last Post: 26th Jan 2009, 08:22 -
Burnt DL playback question on DVD players, Edit: fixed
By WBFAir in forum DVD & Blu-ray PlayersReplies: 6Last Post: 23rd Jul 2008, 11:02 -
WMP11 Error on .mpg and .mpeg playback
By peebee23 in forum Newbie / General discussionsReplies: 14Last Post: 11th Sep 2007, 14:27
