I want to know how to make the avi file smaller by about 40mb or so, so it will fit on a cd. Not too sure how to do it. Its like 755mb and i dont feel like making the file to fit on two cds.
get 90/99 mins cdrs...if your burner supports it
or
cut something out with virtualdub
or
reencode the entire video to lower bitrate
or
BUY THE DVD -
the easiest way would probably be to use VirtualDub and keep it set to direct stream copy for the video and re-encode the audio with a lower bitrate. that way you will not loose any video quality at all and the final file size will be smaller.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
Webcam video file too large (AVI)
By zerozenones in forum Video ConversionReplies: 3Last Post: 13th Sep 2010, 15:32 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
.dv file too large to fit on FAT32 formatted hard drive - not sure of next step
By CBlanchard in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 00:25 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
How to get large avi to fit on dvd while keeping quality
By BrettO in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2007, 09:54
