I have divx pro and installed lame mp3 encoder codecs but when i go into virtuadub none of those options show up. Its just the plain basic codecs. Is there any reason you could think of why this is happening? I had a codec pack, uninstalled it, installed some codecs individually and that didn't seem to help.
Did you restart VD? You would have to do that before new codecs show. Lame MP3 should be available when you select full processing on your audio stream. But Divx should show when you select 'Compression'. If not, you might try a program like RadLight Filter Manager or others that can give you codec information and maybe do some repairs. Codec packs can cause a lot of damage and may not uninstall cleanly.
Originally Posted by redwudz
The methods described in these threads have helped some people who had similar problems:
http://forum.doom9.org/showthread.php?p=124480
http://forum.doom9.org/showthread.php?t=135086 -
Do you think it has something to do with the fact that windows 7 64bit is installed? I tried the stuff in those topics but had no "empty codecs" to delete so i guess it didn't work.
LameACM on Vista64 (probably the same issues with Vista7):
https://forum.videohelp.com/topic332208.html#1723154
The same solution will probably work for Divx.
VirtuaDub Flags. FPS.
By vodmare in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2010, 02:08 -
Quicktime Pro - Getting Codecs to Show in List
By theWallflower in forum Video ConversionReplies: 4Last Post: 8th Apr 2010, 07:00 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 18:47 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
