I have only one dvd recorder in my pc. could you please suggest me a software that can duplicate an original dvd into another one for personal use not using 2 disc exit ( like with nero)
thanks
If you are talking a shop bought commercial disc then
https://www.videohelp.com/tools/DVDFab_Decrypter
and use nero to burn the files it creates on your hard disc.
If it is a non protected disc, and I think your real question is how to do it only having one burner in your PC, then simply use neros copy disc option and it will prompt you to insert a blank disc into your burner when it is ready.
You do not need 2 burners.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Shame on you, marlo!
You've been here five years and you haven't learned how to use search or guides?!
that's simply lazy.
Editing the original Blu-Ray Disc
By K4rm4d0n in forum Blu-ray RippingReplies: 4Last Post: 17th Jul 2011, 09:10 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How Do You Identify Whether The CD You Bought On Ebay Is An Original Copy?
By Nitro89 in forum Off topicReplies: 9Last Post: 22nd Oct 2008, 06:41 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
Avia Original Calibration Disc ??
By ofield1 in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2008, 13:34
