    Jan 2009
    I am having a problem using mpeg stream clip to export my mpeg files to avi. I am trying to get an uncompressed conversion. I don't quite understand why the converted avi file ends up being almost 10 times bigger than the original mpeg file. can anyone explain to me why this occurs and/or what I can do to get an exact size avi of my mpeg?
    Jan 2007
    Republic of Texas
    You have completely different compression schemes. AVI is not MPEG and MPEG is not AVI. Also, AVI is just a container, and you need to know the video codec within. Because of the large file size, you may be dealing with DV-AVI (which is my suspicion) or an uncompressed AVI format. Or... it could be Divx / Xvid avi encoded at an excessively high bitrate.
    Regardless, equal file size does not mean equal quality because they use vastly different methods of compression.
