No matter how hard I try I can't get cropping to work when I re-encode H264 (or x264) MP4 files to lower bit rate versions of themselves. Auto crop and manually set crops show up fine in 'Preview' but are not present in the output files. Cropping works fine when going to other formats - DivX or XviD for example. No filters other than cropping are in use. Any thoughts most welcome.
TIA - GeoffT.
Umm...yes, this doesn't work. Not implemented. All the cropping, adding os subtitles, etc., must be done just like you have noted. Once you select the H264 conversion, few (or none) of the other features are available.
MPEG Streamclip will let you do what you are asking.
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 14:22 -
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 22:25 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
1024x432 MPEG-2 to H264/MPEG4 encodes render as 576x432
By SiRGadaBout in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2008, 06:37 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
