is there any possibility for me to compress 6 gb to 4,7 the size of a dvd?
what kind of files?
Like video and audio files must be reconverted if you want to reduce them so much. -
What type of video files ?
How are they currently encoded ?
Generally, it will mean re-encoding, and if you are going to make them smaller you will most likely take a quality hit.
Personally, DVDs are so cheap, it isn't worth killing the clip to save a few cents. Burn to two discs.Read my blog here.
Reconvert with a lower video and audio bitrate to shrink them(= lower video quality...).
If I will lose the quality then I won't do it. I will just burn more DVDs
Thanks guys anyway!
How do I merge and compress VOB files?
By Mickie in forum Video ConversionReplies: 12Last Post: 24th Jul 2011, 00:30 -
Help - How To De-compress SWF Video Files
By rckowal in forum Video ConversionReplies: 5Last Post: 3rd Jan 2011, 15:37 -
How to compress MPEG4 files for emailing?
By robinh in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2010, 16:00 -
ACVHD files get compress again in rendering?
By yogart in forum Newbie / General discussionsReplies: 11Last Post: 1st Oct 2010, 11:54 -
How to compress files?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2010, 12:42
