  1. I'm running Windows Vista on a VAIO laptop. I just upgraded to DivX 7 Pro, intending to use it with the lastest version of VirtualDub. When I opened up VirtualDub to try to convert a video, it just showed the old DivX 6.8 codecs I had installed before instead of DivX 7.
    I thought this would be an easy one to fix but some time on the forums and on Google has gotten me nowhere. I'll probably smack my forehead when I see the answer... anyway, can anyone help me out?
    Thanks in advance.
    USA
    Did you uninstall the old Divx codec?
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I don't know if that's a good idea, at this point - didn't DivX 7 switch to h264 (VFR/AVC?) video in an MKV container? If they don't have support for encoding DivX 4/5/6/Ultra features in an AVI, any longer, it probably wouldn't be compatible with VirtualDub, then.
    Apr 2004
    Miskatonic U
    I have a sneaking suspicion that the old Divx 6.8.x is the "Divx" part of Divx 7, while the H264/MKV novelty part is what gave it the version upgrade.
    Read my blog here.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep. It's still Divx 6.8.
  6. ah okay, thanks everyone.
