I am converting a .avi xvid to .mov for playback on a mac. I am using procoder 3 wizard.
Does any wise member know the best codec to use for the converson in procoder. Also the picture size is 320 by 240 what size should i make this for Pal?
The encoders listed are H264,Apple Cinepac, Apple DV PAL, H263, Appple H261
Peace
“He who makes a beast of himself gets rid of the pain of being a man.”
Why? All macs can play avi xvids...
But if you really want to, then use h264 video if you want to keep small file size with good quality.
And if it's just for playback on a computer the pal and ntsc doesn't matter. -
Hi Baldrick, the mac I'm using wont play xvid, no codec installed and not going to allow it either.
The file needs to be reasonably small 800 mb tops, this is 120 mins film. It would be good if I could convert to pal.
The movie is going into Final Cut Express for editing.
Thanks for the reply
peace“He who makes a beast of himself gets rid of the pain of being a man.”
Problem Converting AVI (DV) to MOV (DV)
By Casho in forum Video ConversionReplies: 3Last Post: 15th Feb 2011, 06:27 -
Converting avi to mov?
By capman21 in forum Newbie / General discussionsReplies: 7Last Post: 19th Aug 2009, 08:31 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 14:35 -
converting to avi or mov
By scarlac in forum DVD RippingReplies: 1Last Post: 25th Jul 2007, 08:00 -
Converting .mov or .avi to DVD
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 7th Jun 2007, 00:56
