I need to convert some files to mpeg1 so I can embed some files in a powerpoint presentation and have them actually work on the really really old presentation computer.
Anyway, I was able to convert it to mpeg 1 - or so I thought... but it creates two files... .mpv and .mp2 (the sound file).
I tried to "mux" the two together to create a .mpg file. But it didn't work.
What am I doing wrong? Is there an easier way to do this?
I'm a noob so if anyone knows how I can do this using ffmpegx I'd appreciate it.
Thanks.
Failure to mux can be a sign that there is a problem with one or both of the streams. Can you play each in, say, VLC? What are the characteristics of each (resolution, framerate, bitrate)? It might also be worth trying to rename the .mp2 to .mpa. There once was a bug that caused .mp2 to be treated as .mp3 (I think); using .mpa as the extension solved that. I don't know which version of ffmpegx you are using, but there's no harm in trying this simple renaming trick. At worst, it won't work, but you'll know that right away.
I converted the mp4 into .bin and .cue files using the vcd ffmpeg converter.... then muxed that and it looks like it worked!!! Thank you so much for the help!!
I really appreciate it!
Problems converting MP4 to AVI
By Missmax in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 14:40 -
By Nikar in forum Video ConversionReplies: 4Last Post: 17th Jul 2010, 11:39 -
Having problems converting flv to MP4
By Norkusa in forum ffmpegX general discussionReplies: 5Last Post: 16th Aug 2009, 20:54 -
problems converting to mp4
By jedibri17 in forum Video ConversionReplies: 8Last Post: 28th Dec 2007, 22:20 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 20:57
