I have a h264 (mkv) video. well when I encode it to xvid. the xvid got low quality image. of course I set the xvid for full quality mode (I don't care if size too large or take more space) but video seems not good. after I found that h264 used 24 bit color depth resolution and xvid used 8 bit colour depth. Now My question is how to set xvid in 24 bit color depth for get original full quality or which setting will recommended in xvid for get original full quality of the original video file Please help me...
You will never get the original quality. XviD is a lossy format
Older xvid builds had a reduced resolution mode, but the newer builds do not even support this mode. This might be causing the problem. All my encodes are 24-bit with recent builds. What version/build are you using? What software / front end are you using?
For HQ settings, set motion search to very high (6) , VHQ to wide search (4), set the quantizer to 2, set b-frames to zero. If this is for device compatibility, leave Qpel and GMC off. You may have to adjust the profile level to access some settings -
Why xvid is lossy format. every body using this codec for encode their videos. so now which codec is better for get full quality of videoYou will never get the original quality. XviD is a lossy format
Don't re-encode. Just leave the original.
If you want identical full quality, you need a lossless codec (e.g. lagarith, huffyuv). This will make the filesize 10-20x bigger. These are not good for playback because of high bitrates. Again, just leave the original.
h.264 will give you the best compression, but it still is lossy (unless you use the lossless mode, but again, the filesize will be enormous)
The most common reason to re-encode is to make the file smaller, but you will always lose quality (using a lossy format)
If you use a high enough bitrate with any compression, it will look visually identical when playing, but minor differences when examining frame-by-frame and zoomed in.
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
8-bit color RGB versus 10-bit color 4:2:2
By fouronthefloor in forum Capturing and VCRReplies: 4Last Post: 9th Oct 2010, 06:20 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
Color Depth
By gingka in forum Video ConversionReplies: 4Last Post: 20th Aug 2009, 21:53 -
Change Color Depth 24bits to 12bits
By PBoy in forum Video ConversionReplies: 6Last Post: 6th Jul 2009, 13:05
