I live in the UK and am looking for a Prosumer/professional HD 1080 camcorder. The thing is i hope to emigrate to Canada in the next couple of years and don't want to be forking out for another camcorder when i move.
Is there any camera on the market that can redord in both formats, PAl/NTSC????
Cheers
Nostalga 'aint wot it used to be!
Cheers Zoobie,
I will have to save some serious pennies for one of those
Nostalga 'aint wot it used to be! -
you may be able to find one that's cheaper or just buy a NTSC cam
Hi Jagabo,
Thanks for that but i don't use (or plan to use) Final Cut Pro and the JVC creates .mov files as standard.
Although £2,500.00 is a lot cheaper than the sony.
I currently use a VX2000 and VX9000 and really like Sony cameras, so i guess i'll have to save or do a few more weddings
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
Pal and NTSC Camcorder
By NightFire in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th May 2007, 21:01
