I have an Optiarc 7530A ATA DVD on my laptop and for a while I could successfully convert and burn AVI files to DVD and play them on my DVD player. Now they don't work. Its not the player b/c the old DVDs still work and the blank DVD-Rs are from the same spindle as the working ones. I used ConvertxtoDVD and have also tried DVD Santa and Power2Go DVD. All give me the same playback error on the DVD player. THey usually playback on the computer.
I burn to NTSC format. I've tried burning at various speeds, and different sized files. NOthing works!
I think its the DVD drive itself but I can't figure this one out.
If you can help I'd appreciate it!
I would anyway try with another dvd brand and maybe also dvd+r or dvd-rw/+rw.
I guess original dvds work just fine? -
I'll try that although its a DVD recorder and when I insert the same blank DVD-Rs in there it records on them fine. I bought a huge spindle at Costco and its the only ones I've been using since I started burning. I do suspect a problem with the DVD drive, but I cannot figure out what the heck it could be!
It could be your laptop burner. Burners DO good bad, despite consumers believing that they will last forever. It could be your media. Bad media gives poorer results. It could be that your DVD recorder is simply getting old. Or some combo of those things.
Try burning at a slower speed. That sometimes fixes playback problems and that's an easy thing to try.
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 13:29 -
After Encoding Handbrake gives Error and Output video doesn't work
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2011, 09:36 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
region 2 dvd doesn't work with media player classic
By clamchowder01 in forum Software PlayingReplies: 5Last Post: 17th Oct 2008, 23:27 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 02:22
