Hi
I know how to rip a DVD with subtitle to Xvid but if I want to convert my DVD to AVI with no xvid or any other codec that compress my movie.
I know it going to be a BIG file but I going later to create a streaming WMV file so it not going to be a big file when I'm finnish
Why I do it is because I need to create a WMV file that I can use on my streaming server that even have the subtitle.
So how do I need to write so I can convert a DVD with subtitle to AVi with mencoder
Results 1 to 18 of 18
look very good program but when I pick WMV from Container the program freeze
I have try both 0.98.3 and 0.98.4. -
be sure to have download the full package, then update with the automkv0984.exe
BHHHDConvertToX, AutoMen, AutoMKV Developer -
well I have download the full package and then update with automkv0984.exe but is same problem.
I did even try whit the mirror download but same problem -
if on vista try launching as administrator
DOesn't it also require that windows media encoder is installed?
I have that install because I use that to convert file to WMVOriginally Posted by Baldrick
trying to read now at the hompage what I have to do
/Update
After I have read and even download the file from this guide (https://forum.videohelp.com/topic319304.html)
Did download and install Avisynth and AC3 Filter. Have even install "Combined Community Codec Pack" after I have read the information on AutoMKV homepage but still same problem.
It only freeze if I pick WMV from container or codec, not the other like Xvid, MP4... -
please download this file http://www.64k.it/andres/data/a/wmv-profiles.zip
unzip to wmv-profiles overwriting previus xml files
thanks, now I have create a WMV file that I can use on my streaming server but is no subtitle??
I have select a subtitle and I can see in the log that program know I going to use a subtitle but nothing happend?
moviefile.log -
with wmv encoding you MUST encrust subtitle on video
subs will be not switchable
check in advanced settings "Burn subtitle"
well yes I have select the right subtitle, is only one swedish subtitle on the DVD
in movie.idx I have found
Code:# VobSub index file, v7 (do not modify this line!) # # To repair desyncronization, you can insert gaps this way: # (it usually happens after vob id changes) # # delay: [sign]hh:mm:ss:ms # # Where: # [sign]: +, - (optional) # hh: hours (0 <= hh) # mm/ss: minutes/seconds (0 <= mm/ss <= 59) # ms: milliseconds (0 <= ms <= 999) # # Note: You can't position a sub before the previous with a negative value. # # You can also modify timestamps or delete a few subs you don't like. # Just make sure they stay in increasing order. # Settings # Original frame size size: 720x576 # Origin, relative to the upper-left corner, can be overloaded by aligment org: 0, 0 # Image scaling (hor,ver), origin is at the upper-left corner or at the alignment coord (x, y) scale: 100%, 100% # Alpha blending alpha: 100% # Smoothing for very blocky images (use OLD for no filtering) smooth: OFF # In millisecs fadein/out: 50, 50 # Force subtitle placement relative to (org.x, org.y) align: OFF at LEFT TOP # For correcting non-progressive desync. (in millisecs or hh:mm:ss:ms) # Note: Not effective in DirectVobSub, use "delay: ... " instead. time offset: 0 # ON: displays only forced subtitles, OFF: shows everything forced subs: OFF # The original palette of the DVD palette: 000000, 828282, 828282, 828282, 828282, 828282, 828282, ffffff, 828282, bababa, 828282, 828282, 828282, 828282, 828282, 828282 # Custom colors (transp idxs and the four colors) custom colors: OFF, tridx: 0000, colors: 000000, 000000, 000000, 000000 # Language index in use langidx: 4 # English id: en, index: 0 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: English # Deutsch id: de, index: 1 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Deutsch # Espanol id: es, index: 2 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Espanol # Nederlands id: nl, index: 3 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Nederlands # Svenska id: sv, index: 4 # Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x # alt: Svenska # Vob/Cell ID: 1, 1 (PTS: 0) timestamp: -00:00:00:080, filepos: 000000000 timestamp: 00:00:50:680, filepos: 000000800 timestamp: 00:02:25:520, filepos: 000001000 timestamp: 00:02:27:360, filepos: 000002000 timestamp: 00:02:40:040, filepos: 000003000 timestamp: 00:02:50:480, filepos: 000003800 timestamp: 00:02:52:840, filepos: 000004000 timestamp: 00:03:10:000, filepos: 000004800 timestamp: 00:03:38:040, filepos: 000005000 timestamp: 00:03:40:920, filepos: 000005800
there are very few subtitle stringtimestamp: -00:00:00:080, filepos: 000000000
plase ... try opening the movie.avs in virtualdub... you should see the subs too
Strange, I have not see that before. I have a subtitle some minute at the begin of the movie.
So after some minute it disappear
/Update
Is that any way I can rip my DVD from the subtitle and then put in the temp directory and then continue to create my wmv file? -
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19 -
Mencoder exits unexpectedly re-encoding a DVD rip
By ehjd94jvq0 in forum DVD RippingReplies: 2Last Post: 7th Sep 2011, 00:50 -
AVI to FLV using mencoder
By Riotblade in forum Video ConversionReplies: 11Last Post: 13th Feb 2008, 13:00 -
Problem: mencoder - mkv to avi
By Gordo_ in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 06:35 -
Converting MKV to AVI With Mencoder
By Startropic1 in forum Video ConversionReplies: 16Last Post: 25th May 2007, 19:03
