I have a video file : avi : 720x440 (1.64:1) : 23.98fps : Bitrate of 1061
Kbps : quality factor 0.14b/px with a video codec - XviD MPEG-4. The
audio is 2 channel : 48000 Hz sample rate with bitrate of 128 Kbps and
a codec - ATSC/A-52 Dolby AC3. Would appreciate info on how best
to convert it to play in a bought home dvd player. Anything I try is
taking days to encode - please advise what programs I should use and
whether I should convert it to other file types first to achieve inally a
dvd - regards
You have a very old computer, if your specs are correct. Expect conversion to DVD with any level of quality to take many hours, probably at least 24.
If your player can play Divx.Xvid files (look for a Divx logo or mpeg-4 on the case, or consult the manual) then you may be able to burn it to CD or DVD as data and play it as-is. Otherwise you will have to convert it.
Most of the conversion tools are for Windows XP or better, or Windows 2000. You don't way what yours is running, and it is old enough to be running windows 95/98/ME. This could narrow the range of available tools.
I would suggest you try the freeware version of ConvertXtoDVD, known as DivxtoDVD. It is probably the fastest option for your hardware. You can find it here
https://www.videohelp.com/download/vsoDivxToDVD_setup_0.52.99.exeRead my blog here.
Struggling with PAL to NTSC conversion
By ConfusedFormatNoob in forum Video ConversionReplies: 4Last Post: 13th Aug 2010, 21:22 -
Struggling with Panasonic HDC-SD5
By khan.cross in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 5th Aug 2010, 16:49 -
Struggling to convert DV to Computer
By mpcphotographs in forum Video ConversionReplies: 3Last Post: 13th Jun 2010, 11:07 -
Struggling to get this working
By Simon Olley in forum ffmpegX general discussionReplies: 1Last Post: 5th Jun 2010, 08:03 -
Struggling with MKV shrinking
By Lochtsa in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2010, 09:27
