Hi.
I have a problem converting flv files downloaded from one website.
I can view them but not convert them to whatever file format.
FLV files from other places can be converted without a problem.
Even Nero 8 won't recognise the files when I try to burn them to DVD or VCD.
FFmpeg says the the codec isn't reogignised or installed but I've got all codecs installed and can play and convert to nearly every known video file format except for these flv files.
Any suggestion are very much appreciated.
Thanks in advance,
no one will be able to help you unless you post a sample or a link to one of the flv's.
.......thanks a lot for this tip, I'll gave WinFF a try and it did the covertion right away.
Great Prgramm and much easier to use than just FFmpeg.
Srtrange though that FFmpeg didn't convert the files even though it says WinFF won't convert files that FFmpeg won't as well.
Thanks again very much.......Cheng
Converted FLV to MP4-Video OK. Now trying...
By adamberkey in forum Video ConversionReplies: 6Last Post: 1st May 2012, 22:41 -
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 13:05 -
FLV widens subject when converted
By chrisj in forum Video ConversionReplies: 2Last Post: 29th Jun 2011, 16:58 -
Problems with FLV files that I've converted to AVI
By Diana (Cda) in forum Video ConversionReplies: 5Last Post: 9th Dec 2010, 15:09 -
How do I get metadata, especially duration, into a converted FLV?
By benburch in forum ffmpegX general discussionReplies: 2Last Post: 24th Oct 2008, 09:20
