When you viewing a folder's contents, is there anyway to change the default View Settings? I don't want to see Tiles but rather have the Details View Settings every time I look in a folder. There has to be a way to change this?
	open a folder/set it the way you want, click-tools/folder options/view/apply to all folders.
	In XP, change the folder view to Details, then click on Tools -> Folder Options -> View (Tab) -> Apply to Folders. This will make all folders open in the Detail view.
 In Vista, change the folder view to Details, then click on Organize -> Folders and Search Options -> View (Tab) -> Apply to Folders.Read my blog here.
  How to change the IE 7 default setting of webpage Save As?By coody in forum ComputerReplies: 0Last Post: 17th Aug 2009, 14:15
  Is it possible to change the default "Open" view?By SLK001 in forum ComputerReplies: 5Last Post: 22nd Oct 2008, 12:38
  how to delete the TEMP folder contents in windows?By sumeshkri in forum ComputerReplies: 4Last Post: 3rd Sep 2008, 14:27
  Need HTPC software to view multiple folders' contents at onceBy bigshotceo in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:36
  Contents of a Video_TS Folder cannot be compressed??? Help?By DJranman in forum MacReplies: 4Last Post: 19th Sep 2007, 06:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
