Hi, dear all.
Can you point me some methods and softwares to extract subtitles from ratDVD files?
My goal is to extract them to be read using program like Subrip. And after that, transform them into srt "editable" files.
---> https://www.videohelp.com/tools/ratDVD
---> http://ratdvd.ca/
Thank you.
Best regards.
devil (johner)
Hello.
I'll try this.
My fear is that I loose some dvd features in the process. Or, the worst: can't use the subtitles to be read by Subrip
I could find one advice too:
1. Extract the files inside the .ratdvd to an folder
2. Rename file extensions
XVO ----> VOB
VSI---> BUP
3. Extract the subtitles with Subrip
Thanks for help.
Best regards.
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 00:39 -
Extract subtitles from .ts
By anchonio in forum DVB / IPTVReplies: 9Last Post: 16th Apr 2011, 04:07 -
Extract subtitles from VOB files
By webstar in forum MacReplies: 9Last Post: 29th May 2009, 15:34 -
Can't extract DVD subtitles
By idrougge in forum ffmpegX general discussionReplies: 1Last Post: 21st Nov 2008, 13:58 -
How to extract Subtitles from .MKV files?
By kehn in forum SubtitleReplies: 4Last Post: 20th Nov 2007, 06:14
