hello I am trying to connect more than one usb camera to record on my computer, and I bought four cameras sirius 12mp, usb hub and cable with amplifier.These cameras are plug&use and when I conect usb hub and four cameras works normaly.When I add cameras to Active web cam and other programs first camera works good and recording but when I plug second camera the screen become black and show me:
12/2/2009 22:02:57, Camera 2: Error 8007001F: Cannot run preview graph!
If anyone know what is the problem help me! thanks
Unless you have software that is designed specifically for multiple cameras, you will probably not be able to use more than one. While your computer can see the multiple cameras in Device Manager (or System Profiler in the Mac), there is no means to arbitrate the signal among them. This is typical for XP and OSX.
It sounds like you are trying to setup a surveillance system; this takes special hardware and is why these systems cost what they do.
As an alternative, you might be able to use multiple webcams and then link to them from separate webpages you have open on your PC. In this case, your browser just sees them as different websites.
Connect my camera to my pc: Dead FireWire port
By DJSPYDER in forum Newbie / General discussionsReplies: 15Last Post: 6th May 2011, 12:19 -
how to connect an old camcorder to USB capture device
By deanno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2009, 14:40 -
How to connect a USB device to an existing LAN network?
By usta in forum ComputerReplies: 14Last Post: 25th Jun 2009, 15:16 -
Connect a camera
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 2nd Jun 2009, 21:08 -
Can not conect more than one usb camera to record
By harun00 in forum Video Streaming DownloadingReplies: 0Last Post: 14th Feb 2009, 08:51
