    Feb 2009
    I'm trying to burn a VIDEO_TS directory to DVD on my HP G70-212EM, running Vista Home Premium SP1, using the in built DVD writer ( TSST corp CDDVDW TS-L633m ).
    The burnt DVD can be played on the drive it was burnt. However, the created DVD cannot be played on my standalone DVD player ( Sony DVP-NS305 ).
    I have tried a number of burning tools ( Imgburn, Nero etc ), different media ( incl. Verbatim ) at different burn speeds but all result in a standalone DVD read failure.
    I have taken the exact same VIDEO_TS directory and burnt to DVD using my works HP Compaq 6710b, running Windows XP Professional, on the built in DVD writer ( HL-DT-ST DVDRAM GSA-T40L ).
    Using the same tool ( Imgburn ) and the same media ( Verbatim DVD -R 16x ), burnt at the same speed ( 8x ), produces a DVD that can be successfully played on the standalone DVD player.
    I have repeated this test a number of times and every DVD produced on the HP G70-212EM fails to play on the Sony DVD player , whereas every DVD produced on the HP Compaq 6710b succeeds.
    Have I got a faulty DVD writer on my new G70-212EM? Is it Vista issue? Firmware issue?
    I have spent hours trawling the internet for a resolution, but to no avail.
    Please help
  2. It is not a Vista issue. It could be bad discs. It could be that the disc was not finalized.
    Believing yourself to be secure only takes one cracker to dispel your belief.
    Feb 2009
    Don't tools such as Nero and ImgBurn automatically finalize the disk? Or do I need to perform an extra step in Vista? I have heard about 'Mastered' and 'Live File System' format - do I need to do something with these when using the mentioned tools?
    Thanks in advance.
  4. The live file system only comes into play if you use Vista's built in burning engine. The live file system makes the disc a glorified flash drive.
    The is another possibility. You might have chosen a data dvd in which case it would only be viewable on the computer.
