Adobe Encore CS4 keeps giving me this error anytime I try to resize the timeline down to frames when it is past the 1:56:37:13 mark in a project. I have worn out the Adobe forums and no one has an answer. It is an Encore generated message. It has apparently happened to people using After Effects, but the boneheads never post their fix. I found a partial fix explanation, but the super-bonehead did not bother completing his sentence (which he started to explain the fix). As far as I can tell it could be either a RAM thing. The one almost-fixed-it post referred to RAM and turning it off in AE. Any help whatsoever would be greatly appreciated. I am at a huge roadblock in a huge project.
I am on the Adobe forums. So, far we have surmised that it is a program bug. I have installed Encore DVD 2.0 and everything works out okay. It only happens in Encore CS4. I should of mentioned that I own Encore DVD 1.0 and am trying out CS4. I downloaded a trial for 2.0 also.
Error states, "Unspecified drawing error." It is an Adobe Encore generated error.
Results 1 to 1 of 1
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
