Hi.
If the imput file is only 720x576 is this the max I can render at?
Or do/can I still render at HQ 1400x1080?
cheers
You can render at any frame size you want. There's not much point in increasing the frame size though. Enlarging the frame does not increase the resolution -- ie, it will not increase the amount of detail. Even the best "super resolution" techniques offer very little improvement.
What do you intend to do with the video? That's what will determine what you should do with it. -
It is only old home footage that I am doing for a friend
So its not a major project or anything
Maybe his camera (old) had poor quality, or he did not set it right, or used crappy tapes.
Does not matter too much.
Saves him doing it so he will have to be happy with the end project.
Cheers -
You know what I mean
I am not buying expensive software to upgrade it or anything
So as long as it does not cost me money and gets to DVD its good
Compared to used In Studio or something the project is half a#$
Thats the point
cheers
No Audio With Render
By wingspar in forum EditingReplies: 1Last Post: 8th Oct 2011, 17:22 -
What is better to render with?
By ingeborgdot in forum EditingReplies: 8Last Post: 11th Sep 2011, 13:10 -
how to render HD quality with vegas pro
By buffaloboyy in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2011, 11:51 -
Render MPEG-2 for DVD - How to improve quality?
By tripecac in forum EditingReplies: 40Last Post: 16th Jul 2008, 11:26 -
capture without having to render
By sfischer in forum MacReplies: 1Last Post: 6th Mar 2008, 13:09
