Hello
I have WinXP Pro SP3 (up-to-date) and I want to add an internal 1TB HDD but then it occurred to me that my computer is like 4 years old so will I have an issue with the BIOS or motherboard etc.? In other words will it see the 1TB HDD as a single 1TB drive?
Here are my computer details:
So will I be OK with a 1TB interal SATA II / 300 HDD ???Code:# dmidecode 2.9 SMBIOS 2.3 present. 38 structures occupying 1135 bytes. Table at 0x000F0000. Handle 0x0000, DMI type 0, 20 bytes BIOS Information Vendor: Phoenix Technologies, LTD Version: 6.00 PG Release Date: 07/29/2005 Address: 0xE0000 Runtime Size: 128 kB ROM Size: 512 kB Characteristics: ISA is supported PCI is supported PNP is supported APM is supported BIOS is upgradeable BIOS shadowing is allowed Boot from CD is supported Selectable boot is supported BIOS ROM is socketed EDD is supported 5.25"/360 KB floppy services are supported (int 13h) 5.25"/1.2 MB floppy services are supported (int 13h) 3.5"/720 KB floppy services are supported (int 13h) 3.5"/2.88 MB floppy services are supported (int 13h) Print screen service is supported (int 5h) 8042 keyboard services are supported (int 9h) Serial services are supported (int 14h) Printer services are supported (int 17h) CGA/mono video services are supported (int 10h) ACPI is supported USB legacy is supported LS-120 boot is supported ATAPI Zip drive boot is supported BIOS boot specification is supported Handle 0x0001, DMI type 1, 25 bytes System Information Manufacturer: MEDIONPC Product Name: MS-7046 Version: Serial Number: UUID: Not Present Wake-up Type: Power Switch Handle 0x0002, DMI type 2, 8 bytes Base Board Information Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD Product Name: MS-7046 Version: Serial Number: Handle 0x0003, DMI type 3, 17 bytes Chassis Information Manufacturer: Type: Desktop Lock: Not Present Version: Serial Number: Asset Tag: Boot-up State: Unknown Power Supply State: Unknown Thermal State: Unknown Security Status: Unknown OEM Information: 0x00000000 Handle 0x0004, DMI type 4, 35 bytes Processor Information Socket Designation: Socket 478 Type: Central Processor Family: Pentium 4 Manufacturer: Intel ID: 34 0F 00 00 FF FB EB BF Signature: Type 0, Family 15, Model 3, Stepping 4 Flags: FPU (Floating-point unit on-chip) VME (Virtual mode extension) DE (Debugging extension) PSE (Page size extension) TSC (Time stamp counter) MSR (Model specific registers) PAE (Physical address extension) MCE (Machine check exception) CX8 (CMPXCHG8 instruction supported) APIC (On-chip APIC hardware supported) SEP (Fast system call) MTRR (Memory type range registers) PGE (Page global enable) MCA (Machine check architecture) CMOV (Conditional move instruction supported) PAT (Page attribute table) PSE-36 (36-bit page size extension) CLFSH (CLFLUSH instruction supported) DS (Debug store) ACPI (ACPI supported) MMX (MMX technology supported) FXSR (Fast floating-point save and restore) SSE (Streaming SIMD extensions) SSE2 (Streaming SIMD extensions 2) SS (Self-snoop) HTT (Hyper-threading technology) TM (Thermal monitor supported) PBE (Pending break enabled) Version: Intel(R) Pentium(R) 4 CPU Voltage: 0.0 V External Clock: 200 MHz Max Speed: 3066 MHz Current Speed: 3200 MHz Status: Populated, Enabled Upgrade: ZIF Socket L1 Cache Handle: 0x000A L2 Cache Handle: 0x000B L3 Cache Handle: Not Provided Serial Number: Asset Tag: Part Number: Handle 0x0005, DMI type 5, 24 bytes Memory Controller Information Error Detecting Method: 8-bit Parity Error Correcting Capabilities: None Supported Interleave: One-way Interleave Current Interleave: One-way Interleave Maximum Memory Module Size: 1024 MB Maximum Total Memory Size: 4096 MB Supported Speeds: Other Supported Memory Types: Other Memory Module Voltage: 5.0 V Associated Memory Slots: 4 0x0006 0x0007 0x0008 0x0009 Enabled Error Correcting Capabilities: None Handle 0x0006, DMI type 6, 12 bytes Memory Module Information Socket Designation: A0 Bank Connections: 0 Current Speed: Unknown Type: Other Installed Size: 256 MB (Single-bank Connection) Enabled Size: 256 MB (Single-bank Connection) Error Status: OK Handle 0x0007, DMI type 6, 12 bytes Memory Module Information Socket Designation: A1 Bank Connections: 2 3 Current Speed: Unknown Type: Other Installed Size: 512 MB (Double-bank Connection) Enabled Size: 512 MB (Double-bank Connection) Error Status: OK Handle 0x0008, DMI type 6, 12 bytes Memory Module Information Socket Designation: A2 Bank Connections: 4 Current Speed: Unknown Type: Other Installed Size: 256 MB (Single-bank Connection) Enabled Size: 256 MB (Single-bank Connection) Error Status: OK Handle 0x0009, DMI type 6, 12 bytes Memory Module Information Socket Designation: A3 Bank Connections: 6 Current Speed: Unknown Type: Other Installed Size: 512 MB (Single-bank Connection) Enabled Size: 512 MB (Single-bank Connection) Error Status: OK Handle 0x000A, DMI type 7, 19 bytes Cache Information Socket Designation: Internal Cache Configuration: Enabled, Not Socketed, Level 1 Operational Mode: Write Back Location: Internal Installed Size: 32 KB Maximum Size: 32 KB Supported SRAM Types: Synchronous Installed SRAM Type: Synchronous Speed: Unknown Error Correction Type: Unknown System Type: Unknown Associativity: Unknown Handle 0x000B, DMI type 7, 19 bytes Cache Information Socket Designation: External Cache Configuration: Enabled, Not Socketed, Level 2 Operational Mode: Write Back Location: External Installed Size: 1024 KB Maximum Size: 1024 KB Supported SRAM Types: Synchronous Installed SRAM Type: Synchronous Speed: Unknown Error Correction Type: Unknown System Type: Unknown Associativity: Unknown Handle 0x000C, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: PRIMARY IDE Internal Connector Type: On Board IDE External Reference Designator: Not Specified External Connector Type: None Port Type: Other Handle 0x000D, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: SECONDARY IDE Internal Connector Type: On Board IDE External Reference Designator: Not Specified External Connector Type: None Port Type: Other Handle 0x000E, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: FDD Internal Connector Type: On Board Floppy External Reference Designator: Not Specified External Connector Type: None Port Type: 8251 FIFO Compatible Handle 0x000F, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: COM1 Internal Connector Type: 9 Pin Dual Inline (pin 10 cut) External Reference Designator: External Connector Type: DB-9 male Port Type: Serial Port 16450 Compatible Handle 0x0010, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: COM2 Internal Connector Type: 9 Pin Dual Inline (pin 10 cut) External Reference Designator: External Connector Type: DB-9 male Port Type: Serial Port 16450 Compatible Handle 0x0011, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: LPT1 Internal Connector Type: DB-25 female External Reference Designator: External Connector Type: DB-25 female Port Type: Parallel Port ECP/EPP Handle 0x0012, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: Keyboard Internal Connector Type: PS/2 External Reference Designator: External Connector Type: PS/2 Port Type: Keyboard Port Handle 0x0013, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: PS/2 Mouse Internal Connector Type: PS/2 External Reference Designator: External Connector Type: PS/2 Port Type: Mouse Port Handle 0x0014, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: Not Specified Internal Connector Type: None External Reference Designator: USB0 External Connector Type: Other Port Type: USB Handle 0x0015, DMI type 8, 9 bytes Port Connector Information Internal Reference Designator: Not Specified Internal Connector Type: None External Reference Designator: USB1 External Connector Type: Other Port Type: USB Handle 0x0016, DMI type 9, 13 bytes System Slot Information Designation: PCI0 Type: 32-bit PCI Current Usage: Available Length: Long ID: 1 Characteristics: 5.0 V is provided PME signal is supported Handle 0x0017, DMI type 9, 13 bytes System Slot Information Designation: PCI1 Type: 32-bit PCI Current Usage: Available Length: Long ID: 2 Characteristics: 5.0 V is provided PME signal is supported Handle 0x0018, DMI type 9, 13 bytes System Slot Information Designation: PCI2 Type: 32-bit PCI Current Usage: Available Length: Long ID: 3 Characteristics: 5.0 V is provided PME signal is supported Handle 0x0019, DMI type 13, 22 bytes BIOS Language Information Installable Languages: 3 n|US|iso8859-1 n|US|iso8859-1 r|CA|iso8859-1 Currently Installed Language: n|US|iso8859-1 Handle 0x001A, DMI type 16, 15 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: None Maximum Capacity: 4 GB Error Information Handle: Not Provided Number Of Devices: 4 Handle 0x001B, DMI type 17, 27 bytes Memory Device Array Handle: 0x001A Error Information Handle: Not Provided Total Width: 64 bits Data Width: 64 bits Size: 256 MB Form Factor: DIMM Set: None Locator: A0 Bank Locator: Bank0/1 Type: SDRAM Type Detail: Synchronous Speed: Unknown Manufacturer: None Serial Number: None Asset Tag: None Part Number: None Handle 0x001C, DMI type 17, 27 bytes Memory Device Array Handle: 0x001A Error Information Handle: Not Provided Total Width: 64 bits Data Width: 64 bits Size: 512 MB Form Factor: DIMM Set: None Locator: A1 Bank Locator: Bank2/3 Type: SDRAM Type Detail: Synchronous Speed: Unknown Manufacturer: None Serial Number: None Asset Tag: None Part Number: None Handle 0x001D, DMI type 17, 27 bytes Memory Device Array Handle: 0x001A Error Information Handle: Not Provided Total Width: 64 bits Data Width: 64 bits Size: 256 MB Form Factor: DIMM Set: None Locator: A2 Bank Locator: Bank4/5 Type: SDRAM Type Detail: Synchronous Speed: Unknown Manufacturer: None Serial Number: None Asset Tag: None Part Number: None Handle 0x001E, DMI type 17, 27 bytes Memory Device Array Handle: 0x001A Error Information Handle: Not Provided Total Width: 64 bits Data Width: 64 bits Size: 512 MB Form Factor: DIMM Set: None Locator: A3 Bank Locator: Bank6/7 Type: SDRAM Type Detail: Synchronous Speed: Unknown Manufacturer: None Serial Number: None Asset Tag: None Part Number: None Handle 0x001F, DMI type 19, 15 bytes Memory Array Mapped Address Starting Address: 0x00000000000 Ending Address: 0x0005FFFFFFF Range Size: 1536 MB Physical Array Handle: 0x001A Partition Width: 0 Handle 0x0020, DMI type 20, 19 bytes Memory Device Mapped Address Starting Address: 0x00000000000 Ending Address: 0x0000FFFFFFF Range Size: 256 MB Physical Device Handle: 0x001B Memory Array Mapped Address Handle: 0x001F Partition Row Position: 1 Handle 0x0021, DMI type 20, 19 bytes Memory Device Mapped Address Starting Address: 0x00010000000 Ending Address: 0x0002FFFFFFF Range Size: 512 MB Physical Device Handle: 0x001C Memory Array Mapped Address Handle: 0x001F Partition Row Position: 1 Handle 0x0022, DMI type 20, 19 bytes Memory Device Mapped Address Starting Address: 0x00030000000 Ending Address: 0x0003FFFFFFF Range Size: 256 MB Physical Device Handle: 0x001D Memory Array Mapped Address Handle: 0x001F Partition Row Position: 1 Handle 0x0023, DMI type 20, 19 bytes Memory Device Mapped Address Starting Address: 0x00040000000 Ending Address: 0x0005FFFFFFF Range Size: 512 MB Physical Device Handle: 0x001E Memory Array Mapped Address Handle: 0x001F Partition Row Position: 1 Handle 0x0024, DMI type 32, 11 bytes System Boot Information Status: No errors detected Handle 0x0025, DMI type 127, 4 bytes End Of Table
Oh and if you don't want to read that big long CODE of stuff I think the two important things are the motherboard and BIOS information:
1.) Motherboard = MSI MS-7046 which is an Intel 915P chipset (I think)
2.) BIOS = Vendor is Phoenix Technologies, LTD and the version is 6.00 PG
I hope that helps
- John "FulciLives" Coleman
Results 1 to 10 of 10
sure why not? Can your BIOS see drives larger than 120gig? If so then no problems...I had one 5 yrs old...BIOS update made it all possible.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Well I currently have two 320GB SATA II / 300 drives and no issues but I didn't know if 1TB was "too big" for my computer or not. I know of the old 120GB restriction which is long gone now but I didn't know if there was a new restriction or if any size goes these days?
P.S.
This is the drive I will be buying: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
It is SATA II / 300 but it should be backwards compatible with SATA I / 150 right? I mean my motherboard is only SATA I /150 and yet my 320GB SATA II / 300 drives work fine."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
It should work though the drive will have to operate in SATA mode (not SATA II) since that's what the chipset supports. The drive will automatically select the right mode.
John Miller -
OK kewl. I was just reading through the comments on newegg.com and someone said this drive will work with SATA I / 150 only connectors ala my motherboard.Originally Posted by JohnnyMalaria
Now do I order it and wait or spend $5.00 more + sales tax and get the retail version at BEST BUY tonight ... decisions decisions LOL
I know what I'd do - much easier to deal with returning it should it not work.
Just get it..piece of mind. if something wrong, you can jump back into car or girls car and return or exchange.
I'm looking for HDD upgrades myself, too. I have the ECS GeForce6100SM-M motherboard, and I think it does say SATA drive support, but I don't know anything about sata or eide or whathaveyou, and store shelves have all kinds of these drives and I'm not sure which one I'm suppose to get for my motherboard, though I do have a regular ide 160g hdd in it now. So, I leave it alone, and just go for the externals--much easier and less headacke.
I was browsing around best buy myself, today..and saw an $89 dollar 500g external drive, but hesitated and then finally decided not to get it. Then I saw those tiny little 320/500g passbook drives but they were too much for me, pushing $149, and I just wasn't sure they would be enought for my analog (raw) captures, unless I used a software dv codec: I use it for my analog cabletv captures to my usb-2 external 160g hdd with never a problem, though even raw captures using huffy or lagarith was no trouble either. But those 5400 rpm drives have me worried they won't work for the raw captures..so I decided against those, too.
..OT..
I also went to circuit city, now advertising 30-60 percent off. DVD/Music were 50 percent off, though I didn't get any: I must have had 5 titles in my hand before I finally said, "nah..not waisting any more money on these" and put them on the shelf. Then I made my way over to the camcorder section, where I was hoping to score big on a Canon H-20 (1920x1080) models that everyone was talking about over here, but they didn't have any that I could find, except a couple of Sony's that were 1920 res but said nothing else. Then I saw a BluRay usb-2 writer but $230 bucks, in a red box though, by Buffalo: if anyone's heard of it, do tell. And it said it can read BlueRay; HD-DVD; DVD; and CD; and also: write BluRay; DVD; and CD; but I wasn't sure, so in the end, I didn't get it because I wasn't sure that that was a good price, unless someone corrects me on this, and I'd go back. But who sells bluray recordable media anyway--besides no_one. Yeah, while at best buy, I did see a couple of BluRay rom drives selling for $100 bucks, but they only READ disc's. But if that blueray writer is a good deal, i'd give it another shot at the tripping it, tomorrow: I know where its hiding, hehe..
Actually, fulci, these days, I'm looking only for exernal type devices: be it HDD's and Writers or Capture equipment, and even Sound cards. I Just remembered..I did see the tinyiest soundblaster usb-2 sound card, about the size of my pinnacle pctb hd card. It was selling for $49 bucks: almost got that too, but said, nah.. just like before, gosh. So I was thinking about that, too. But I just want to plug and go with everything I can, just as the vision was ment to be, 10 years ago or so back in the gold-ol windows 98 days.
My external 160g usb-2 hdd works find under XP..can capture as raw or (dv) codec without any trouble. And it actually works fine under my Windows 98 as well.
But my only worry about the 500g or higher (external drives) is the same as yours, will it be recignized under Windows Xp sp2, mine, is home edition.
sorry for rambling on in your post, I was also in the naiborhood and got overloaded with, "go on..get it..waist your money, no one cares, go bank-krupt and what-nots"
-vhelp 5041 -
FYI if you decide to buy it from BEST BUY make sure you open up that hard drive box at the register after you pay for it. There have been reports of consumers buying SEAGATE retail hard drives from BEST BUY but when they open up the box at home they find a used SAMSUNG or another brand hard drive. A few years ago someone posted a thread about that and how difficult it was to prove to BEST BUY that the pos hard drive was in that supposedly brand new hard drive box.Originally Posted by FulciLives
Now whenever I buy a hard drive from BEST BUY I open up the box at the register after I pay for it. On one occasion I did open up the box to find the seal on the antistatic bag was already torn. I immediately got a full refund since there were no more in stock. BEST BUY doesn't check their return merchandise, they just shrink wrap the boxes & put them back on the shelves. So beware!
BTW the one you're looking at Newegg would be better because the one at BEST BUY that's $5.00 less is a 5400rpm hard drive. The one at Newegg is 7200rpm.
http://www.bestbuy.com/site/olspage.jsp?skuId=8492026&type=product&id=1186003685416
Here's the one at BEST BUY that's the same as the Newegg one you linked to:
http://www.bestbuy.com/site/olspage.jsp?skuId=8909595&type=product&id=1213047091732 -
@ Budz
Actually I was talking about the one in the 2nd link ... the "black" edition. It is on sale right now at BEST BUY although I assume that ends tonight.
It's 8:49pm and BEST BUY closes tonight at 10:00pm and it's a good 15 - 20 minute drive.
I better get my butt in gear or just order it from newegg.com
If you have Fry's near by check it out first sometimes they have good deals better than newegg. Specially on HD and PSU
http://www.frys-electronics-ads.com/
Problems accessing Seagate 1TB external HDD via Sumvision cyclone Micro HD
By julie_152 in forum Media Center PC / MediaCentersReplies: 6Last Post: 27th Feb 2011, 06:33 -
Looking for a new 1TB internal drive. Seagate too many issuses now?
By Denvers Dawgs in forum ComputerReplies: 9Last Post: 12th Jun 2010, 06:37 -
Buffalo 1TB HDD HD-CX DriveStation with Hardware Encryption
By kyrcy in forum ComputerReplies: 0Last Post: 21st Feb 2010, 09:19 -
windows xp home computer no longer sees my 1TB usb-2 external hdd .. [RESOLVED]
By vhelp in forum ComputerReplies: 8Last Post: 28th Jan 2010, 13:00 -
What will I need to add a 1TB internal hard drive to my PC?
By Captain Satellite in forum ComputerReplies: 12Last Post: 9th Dec 2008, 09:17
