I have ripped Toy Story 2 to the hard drive. This plays in sync perfect. However if I load it into DVD2Avi and then load the d2v file and wav into TMPGenc, it is about 2 seconds out.
I have tried many other programs and its the same sync problem. How come the DVD plays perfect in any program I use but trying to extract it makes sync issues?
Results 1 to 21 of 21
What did you rip it to the hard drive with? My first guess is that there is about a two second video clip before the main movie that has the start of the audio track and it was deleted during ripping.
If that's what caused the sync problem, not sure of a simple cure, but others here may. Or I may be completely wrong. Never had that particular problem, but I usually use DVDFab HD Decrypter or AnyDVD to rip. -
I have tried several ways. AnyDVD and draggin the VIDEO_TS folder over in windows, used DVDFab 5, used DVD Shrink with AnyDVD in background. They all work when playing in a DVD software like WMP, but when editing, it is 2 seconds out.
Jagabo, please do not reply to this post. Thank you. -
My guess is that the files from the rip have a delay value to keep the A/V sync that you are losing when they are demuxed. I don't use the tools you use so I can't tell you where to look for ways to set an audio delay.
Buy My Books -
Do you know what ways I can tell if there is one and how to correct it?Originally Posted by gadgetguy
Buy My Books -
Just gonna give it a go and I will get back to you.
Nope, same problem. Video is coming out at 1:28:36 while audio is 1:28:34
I don't use TMPGenc so I don't know if there's a way to set an audio delay, but if you put it though an AVISynth script you can set DelayAudio(2) and then feed it to TMPGenc. I believe you'll need the DGIndex plugin for AVISynth to open the d2v file. Another option would be to open the wav file in Audacity and add 2 seconds of silence at the beginning.
Buy My Books -
Is there a way to do it without messing with audio delays and stuff like that? The thing I do not get is why in players, it plays PERFECT, just editers cant see it the same way.
The source has a delay value in it that tells players how much to delay the audio when played back. When you demux that value is lost so YOU have to compensate for it somehow, so no.
Buy My Books -
Where can I see this value? The 2 seconds is a rough guess. Is there a way to see this information?
Not sure. When I demux a file using DGIndex, the delay factor is in the filename of the audio file, but I don't know if DGIndex will work in your process.
Buy My Books -
I have just tried that program, it has got to the end and is saying something about Field Order Tranistion Detected. Do I press yes or no?
Toy T80 3_2ch 448Kbps DELAY 0ms
That is the filename it is giving me. That can't be right cos there is a delay but the filename says 0msJagabo, please do not reply to this post. Thank you. -
That error usually indicates lost data/file corruption. Preset audio delay might not be your problem after all. Let it try to correct the field order problem.
Edit: By the way, that doesn't look like a wav file. It looks like ac3."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
It is giving me that error on every DVD i just tried. Is it because I going through Shrink first?
Possibly. Again, I don't use the tools you've mentioned so I don't know how they do what they do, nor what settings you should or should not be using. (Not to mention that I seldom rip and convert my DVDs.)
Buy My Books -
Is there another way to detect audio delay?
I don't know of any.
Buy My Books -
Right, I managed to solve this problem. The ONLY program that would output the files in sync was VideoRedo. The MPG it produces I can load up in VdubMod and edit that way. Was a long way but I got there. Thank you for everyone who helped. I really do appreciate it. I have said it before and I will say it again, this board is the most helpful and friendly I have EVER been on.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
Trying to understand audio editing
By Snakebyte1 in forum AudioReplies: 1Last Post: 22nd Feb 2008, 13:53 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
