I'm watching bluray rips through another computer by local network (because I don't have a big hard drive right now), but the sound doesn't work at all, it only works when I copy the file to my PC.
Anything I can do to get it working?
thanks
Assuming you are just playing the file from the remote PC. It should be working the same as local. Unless maybe the remote PC isn't transferring quickly enough, but in that case I'd expect the video to be choppy as well. If you are streaming, then that's another issue.
Google is your Friend
Solution to Slave drives not appearing on local network
By Gabriel in forum ComputerReplies: 9Last Post: 21st Feb 2012, 09:15 -
How to stream audio file to another PC within local network
By LanguidLegend in forum Video Streaming DownloadingReplies: 4Last Post: 13th Oct 2011, 14:47 -
streaming video stored on one pc to my local network
By cougs_83 in forum Video Streaming DownloadingReplies: 19Last Post: 6th Sep 2011, 11:03 -
Playing mkv with MPC-HC doesn't work as it should
By ronlut in forum Software PlayingReplies: 7Last Post: 6th Jul 2010, 18:13 -
questions about LAN (Local Area Network)
By jimdagys in forum ComputerReplies: 14Last Post: 14th Nov 2007, 20:58
