I have a HD ready TV with ONE HDMI port , it is currently been used by my PHILIPS DVP5980 but I hope to get SKY+HD soon and that means I would have to swap em over... are these HDMI cable splitters any good? or do you lose quality with having TWO connected?
You need an HDMI switch, not an HDMI splitter. Here's an example. http://www.oppodigital.com/hm31/ Of course prices and selection will be different in the UK.
whats wrong with an HDMI splitter? - if u cant use them whats the point of em>?
i refuse to spend £100 on summit for that job - I would rather put the extra too and get another TV with more ports , i would rather use a splitter cable or manually change em until i get a better TV
Take your pick: http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10110
I got a 3x1 for approx. $30 a couple of years ago and it senses when you turn on a new device and switches automatically. I don't even use the remote. Recommend getting at least the 3x1 so when you pick up that bluray player or PS3 next year.
I love children, girl children... about 16-40
W.C. Fields -
Like all splitters, they split the signal and the signal strength to your display is reduced. This can affect your PQ. Switchers often have signal boosters built in.Originally Posted by snadgeI love children, girl children... about 16-40
W.C. Fields -
Splitters are for sending the output from one source to multiple devices simultaneously. Splitters do not necessarily work equally well in both directions. A splitter would be useful if you wanted to watch the same channel output by your SKY receiver in multiple rooms.Originally Posted by snadge
Switches are used to select the output from one of several available sources for a single device.
HDMI splitter
By levl in forum Newbie / General discussionsReplies: 12Last Post: 28th Jun 2014, 15:30 -
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
HDMI cable seems worse than RBG cable
By BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 18:27
