  1. Member wulf109's Avatar
    Jul 2002
    I just installed an E5200 in a computer and I wonder what temperatures to believe. I'm running the CPU at 3.8Ghz. Gigabytes own hardware monitor reports my load temps in the low 40's,Speedfan reports the same temperature as Temp 2. Speedfan also reports a Core 0 and a Core 1 temperature. Core 1 is in the mid 60's and Core 2 is in the high 50's. Which one do I believe?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    For E5200 you should use the Real Temp, set TJ max to 100.
    Real Temp Download
    http://www.techpowerup.com/realtemp/
    You can also check out extremesytems forum.
    http://www.xtremesystems.org/forums/showthread.php?t=179044
