I have an SVCD mpeg that I want to multiplex. Tmpegenc won't open the file for multiplexing and reports the following error:
"Illegal MPEG stream."
However, the mpeg does play in Windows Media Player but will NOT play in PowerDVD. Can someone tell me how I can fix this mpeg? Thanks.
P.S. The mpeg is Monsters Inc. SVCD in case that helps.
Play the file in Media Player, and check the properties, and let us know which codecs are being used to decode the MPG file, your problem might just be a mix of decoders fighting for the file.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi there,
I do also have a prob with TmpegEnc I have this SVCD and want to convert it to VCD since my Standalone doesnt accept this format whatsoever..well everytime I try to simple multiplex the SVCD the program freezes
heres what I do:
Simple Multiplex Tab
Video Input :SVCD(my mpeg2 file)
Audio Input :SVCD(my mpeg2 file)
Output:I use another name for the output file
Type:Mpeg 1 VCD
any help please??? -
Ok, both of you, if your file IS an SVCD, why are you trying to multiplex it ?
If you want to convert it to VCD, you need to do encoding, not multiplexing.Email me for faster replies!
Best Regards,
Sefy Levy,
well I read somewhere to convert it like that...
have to try your method though is the quality the same as in SVCD??? -
#1 the multiplex trick only works sometimes. make sure you set the type feild to mpeg-1. this will make a sort of bastardized form of XVCD that will play on some players that support XVCD playback but not ALL players.
#2 when you run this MPEG tool it may seem that the program has locked up or that nothing is happening. be paitent here and dont end it prematurley. get up and walk away and come back in 10 or 15 minutes. there is no status indicator to show you the progress but it is working, just give it some time. unless you get an error message then it is running.
if you really think it has stoped then press ctrl+alt+del and look and see if it is reporting that the program has stoped responding.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
thats exactly what happened to me the program really "Freezes"...
I press ctr alt del and it shows the "lockup"
well I have to buy me another player then :(
thanx guys
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 05:00 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 15:52 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 01:25
