    Feb 2009
    Hi Sorry I Understand Many People Have Asked This, But
    I Am Using A Tevion DVD Maker To Capture Xbox 360 Non-HD Gameplay, Using Splitters And A Coupler.
    But The Quality Is OK, But Ive Been Told That With Different Capturing Program, Comes Better Quality Or Worse.
    Cause Im Using Windows Movie Maker Right Now Which Is Simple, But I Was Wondering Whats The Best Program That If Its True, Brings Better Quality?
    And Im Asking Another Question, But It Applies To Anyone Who Has The Same Capture Card, Which Is Known In The USA As A K-World DVD Maker.
    After Capturing Whatever Video Footage, Whats The Best Settings You Use In Sony Vegas, For Youtube?
    Feb 2004
    Australia
    Welcome CLOUID
    Better capture using other capture software ... yes and no
    A: The software must be capable of using the device
    B: Depends on programs design and features, ie, better or worse quality (not a capture device fault)
    Settings for sony vegas depend on source and output and are too varied.
    What works for one job may not meet the requirements for the next (close is second best).
    Personally, I do not use sony vegas as part of any flv conversion.
    Your happily working with wmm and having no problems, then stick with it and output source as dv-avi for use in vegas
    Remember what you upload to youtube will be re-encode should it pass the acceptable bitrates youtube allow's.
    You can either upload source with higher rates and acknowledge the fact after youtube has re-encoded it, that there will be loss of quality.
    Or create final source that match's youtube's requirements which should appear shortly for all to see.
    I choose the second ... normally my clips are up and running after 5 minutes
    Better capture results come from better designed capture hardware ... software is secondary.
    Feb 2009
    Thank You, I Found Quite Of Couple Of Tuts For Xbox 360 Recording And Conversion To Youtube.
    I Will Stick With WMM, And Try The Dv-Avi. Thank You BJS
