  1. How to stop Window Explorer opening when inserting VCD?
    Every time I place a VCD into the cdrom Window Explorer opens. How do I stop Winxp from doing this.
    I have gone to Folder properties and have selected "Take no Action" for all of the selection but still continues to open up the Window Explorer.
    Where do I change this annoying property?
    SeeYa
    Never Say Never (Romeo Void 1981)
    Firefox, Thunderbird
  2. You have associated the VCD file to Explorer. To fix, put the disk in the drive and in Explorer highlight the largest file (the media file) probably a .dat file. Right click and pick "Open With" and "Choose Program". Pick the program you want to use and tick the "Always use the selected program to open this kind of file" Then click OK. Your done.
  3. Sorry I want to stop Window Explorer from opening not start it with a program.
    I do not want to AutoPlay.
    Am I not explain the problem properly?
    SeeYa
  4. Keep the shift key pressed while inserting the disc.
  5. Banned
    Jun 2007
    UNREACHABLE
    Add the name of your CD/DVD unit to the following Registry Key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdrom\AutoRunAlwaysDisable
    , then reboot the PC.
    HTH.
    P.S.: Choose a better avatar next time.
