I had a movie which contained subtitles embedded in the.mkv file, so i extracted the 3 streams (video, audio and subtitle using mkvextract, all did fine, the using mkvmerge i put the video and audio back together, but this has made the movie out of sync now. What is the best way to sort this out???
Cheers
Russ
Don't use mkvextract
Use mkvmergegui on the original mkv, checkmark the streams you want, uncheckmark the streams you don't want, press merge -
Because the delay isn't preserved upon extracting, so unless you remember what it was when you made the .mkv , or you have a timecodes file, it will become out of sync when you mux the video & audio. The easiest way to keep the synchronization is to do what I suggested. I don't see a good reason to extract the subtitles, you can turn them on/off in most players
Please Help... Audio and Video in movie (avi) get out of sync!!
By dezerteagle323 in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2010, 22:00 -
Subtitles dont sync with the movie
By j_kremer in forum SubtitleReplies: 3Last Post: 31st Mar 2010, 18:33 -
The sound sync is off about 30 minutes into the movie
By Genetics in forum Newbie / General discussionsReplies: 5Last Post: 20th Jul 2009, 22:26 -
taking audio from one movie to sync in a movie
By bigdaddykane in forum AudioReplies: 9Last Post: 28th Dec 2007, 14:40 -
Audio not sync in movie
By De_JA_Vu in forum AudioReplies: 1Last Post: 15th Jul 2007, 15:59
