I started shopping around for a replacement CD burner for my laptop, but it seems they're all 24X
Can I buy an internal laptop CD burner than can burn at 32x or 40X?
I guess not.I just checked newegg.com nothing over 24x for cd's and 8x for dvd's .
or you have to go external if you want speed over 24x/8x
you have no patient to wait few extra min's?
Yeah I found the same thing on newegg too. I use good quality CD-R and they burn fine at higher speeds, never had a complaint about not being able to play one of these discs.. I wonder why there's such a limit...
The speed is probably limited for laptops to limit power requirements for the battery.
Probably also to limit vibration - they are not as sturdy as desktop units."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
I use an external Pioneer or Sony drive.
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56 -
Limited Internet
By Nitro89 in forum ComputerReplies: 10Last Post: 18th Feb 2008, 13:56
