This is my final post regarding Vista to XP and drivers.
I received my computer today and I am going to try to get all my final questions answered here before downgrading to Windows XP Home 32-bit.
My desktop is the HP Pavilion Elite m9500t.
This is the site to my motherboard specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&lc=en&dlc=en&cc=us&produ...911798&lang=en
I have copied and pasted some of the information from the link above:
- Motherboard description: Motherboard manufacturer's name: Asus IPIBL-LB (HP/Compaq name: Benicia-GL8E)
- CPU/Processor: Socket: 775
- Chipset: Intel G33
- Video graphics: Integrated graphics using Intel GMA 3100
- RAID: Onboard RAID controller: ICH9R
- Onboard audio: Audio CODEC: ALC888S; 7.1 channel high-definition audio
- Onboard 1394: Agere LFW3227 controller chip
Questions:
1.) This desktop is customized with 256MB NVIDIA GeForce 9300 [DVI, HDMI, VGA adapter]. Do I still need to install the video graphics driver that is on the motherboard (Intel GMA 3100)?
2.) Going to Intel's website and searching the Intel G33 chipset, I found the following drivers:
- Intel® Graphics Media Accelerator Driver for Windows* XP (exe)
- Intel(R) Matrix Storage Manager
- INF Update Utility - Primarily for Intel® 4, 3, 900 Series Chipsets
The link is: http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2842&OSFull...bmit=Go%21#DRV
There are .zip versions also but the description says that it is for developers/advanced users.
Do I need all three drivers?
3.) The drivers link above lists two types of graphics driver:
- Intel® Embedded Graphics Drivers (IEGD) - For embeded developers only.
When asking HP to provide me with drivers, HP gave me the Intel Embeded Graphics Drivers but not the Graphics Media Accelerator drivers. Which one should I download?
4.) For SATA drivers is the following correct?:
Description: This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2842&DwnldID=17268&st...ition&lang=eng
Or am I supposed to obtain it from the motherboard manufacturer (Asus)?
5.) I customized my computer with 256MB NVIDIA GeForce 9300 [DVI, HDMI, VGA adapter].
So my monitor will be connected to this graphics card rather than the motherboard.
I plan to install drivers for this card after the XP install rather than during the XP install process. When XP is installed but before I install the driver, will my monitor work?
6.) I may try installing XP first without slipstreaming any drivers with nlite. If that does not work and the computer does not recognize the the hard disk, will I still be able to get back into Vista so that I can create a slipstreamed disc?
Closed Thread
No more new posts from me regarding Vista to XP. This is my last one.Originally Posted by MOVIEGEEK
It's not that I don't like Vista. I just have Premiere Pro 1.5 that is not compatible with Vista and I have a project that was not completed when my laptop crashed. Otherwise I would stay with Vista.
Yep. Please stop make new similar topics. Continue in your first one.
https://forum.videohelp.com/topic364330.html
Where can I find a Vista driver for my Dynex sound card?
By Obamargarine in forum ComputerReplies: 7Last Post: 5th Mar 2009, 07:26 -
Questions about sysoc.inf and msconfig in Vista
By Xylob the Destroyer in forum ComputerReplies: 2Last Post: 10th Dec 2008, 15:08 -
WDM Driver programming questions
By cybertheque in forum ProgrammingReplies: 0Last Post: 8th Nov 2008, 19:14 -
XP -Vista Questions
By SIRCOOKS in forum ComputerReplies: 13Last Post: 28th May 2008, 14:35 -
dual boot vista and win98? driver issues? need floppy drive?
By yoda313 in forum ComputerReplies: 11Last Post: 7th Apr 2008, 20:57
