Hi all.
I am using Womble's Mpeg Video Editor v4.0. Imported two mpeg videos in the timeline to join together. Fig-1.
Earlier, I could drag them in the timeline to wherever I wanted (e.g. swap their positions etc.). But now, I cant do that. A 'NO' sign appears, (the one that resembles a donut with a slash across it).
Please help.
Thanks.
Amer
Results 1 to 10 of 10
Hi
Make sure that the track isn't locked. Right click on the camerra to the left of the track and choose unlock.
Brainiac -
Hi.
Thank you for your response.
Its not locked. I think when you have it locked it displays a 'lock' symbol there.
Amer -
I cannot duplicate your problem. Have you tried the latest version? It's worth a try if not.
Brainiac -
donut with a slash? I think that means the file referenced has been moved or deleted.
If the file were deleted or moved there would be an x on the lower right corner of the file on the timeline and in the browser. But I did notice that there is no video showing on either of the monitors. Try another file on the timeline and see what happens.
Brainiac -
I haven't had that issue either, but you can try right clicking on a gap, and select "Clear All Gaps". That would effectively join them, if that's your goal, albeit in a work-around. I'm not sure what is going on for you.
Hi all friends.
Thanks very much for all your kind suggestions.
The problem got solved by reinstallation.
Best Regards,
Amer -
I had the same problem, but it did not solve by re-installing alone.
I had to delete some of the files in the settings directory which is hidden somewhere in
\Users\...\AppData\Local\VirtualStore\Program Files (86)\Womble Multimedia\MPEG Video Wizard DVD\Configs
I seem to remember that I had the same effect before, and I solved it by deleting several of the entries
in the Project - Clip - Video window... -
Update:
Stop MVW
Search for the file TimeLine.cfg in the above mentioned directory or whereever MVW stores its config.
Edit this file and change the entry
InfoBox= 0 0 0 1
into
InfoBox= 0 0 0 0
Save the file and restart MVW.
The clips can be moved by drag and drop again.
Greetings
David
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 19:32 -
MPEG Editor like Womble but with 2 video tracks?
By greymalkin in forum EditingReplies: 26Last Post: 19th Jan 2010, 06:52 -
Problems with womble dvd editor
By auto7890 in forum EditingReplies: 3Last Post: 1st Sep 2008, 23:21 -
Womble or TMPGEnc MPEG Editor?
By Mike99 in forum EditingReplies: 14Last Post: 11th Aug 2008, 09:32 -
Womble MPEG Wizard - Bookmarks
By terrypin in forum EditingReplies: 0Last Post: 18th Jun 2007, 13:45
