hi , i have monitor with tv tuner(combo).I connect this monitortomy pc and i wath some ffilm from my pc, and watch tv from my cable tv.My question is-can i record TV from TV tuner to my PC?And if i can,what i have to do fot this?what is the program or software forthis,or i have to buy any cable to connect my combo to pc?Please help me.Thanks
Doesn't the tv tuner include some software? Start with it.
If it's analogue:
https://www.videohelp.com/tools/sections/capture
and DigitalTV/DVB
https://www.videohelp.com/tools/sections/digitaltv-dvb-hdtv -
The combo monitors with an integrated TV tuner that I have seen only have connections for antenna or cable in, video in, and audio out. With no video out connections, it is impossible to use your monitor for recording TV on your computer.
You can ignore my post if you have a monitor with builtin tuner....I thought it was a separate tuner(with digitaltv and analog combo
) for you computer as you need a such for be able to capture anything using software of course.
I would say that you have a regular TV that also has a VGA port on it (most newer sets have this). You will NOT be able to capture any video to your computer using the television's built in tuner.
What you need is a dedicated capture card.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 01:42 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 07:31 -
receive live video from TV tuner and stream it via Ethernet
By mb508 in forum Newbie / General discussionsReplies: 5Last Post: 21st Sep 2007, 05:53
