I have a FLV video and I want to transfer the video & audio stream to AVI (wihtout re-encoding, that means I don't want to loss any quality from the original video). I use AVI for destination container because I want to edit it with virtualdub later.
This is the FLV video information extracted by MediaInfo:
So I will use SUPER 2009 to do the task. There are the options I would select:Code:Format : Flash Video File size : 13.1 MiB Duration : 6mn 17s Overall bit rate : 290 Kbps Tagging application : FlixEngineLinux_8.0.10.1 (www.on2.com) Video Format : VP6 Duration : 6mn 17s Bit rate : 212 Kbps Width : 352 pixels Height : 200 pixels Display aspect ratio : 16/9 Frame rate : 30.000 fps Bits/(Pixel*Frame) : 0.101 Stream size : 9.79 MiB (75%) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Duration : 6mn 17s Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 5ms Stream size : 2.88 MiB (22%)
1. I choose "AVI" in "Select Output Container".
2. I choose "FFmpeg" for the encoder.
3. I check "Stream Copy" in Video section.
4. I check "Stream Copy" in Audio section.
I've tried it with that settings and the FLV video was transfered to AVI successfully. But what I'm very concerned is the quality of the output video (AVI).
The question:
After what I've done above, is there any quality loss in the output video (AVI) compared to the source video?
Of course, as we know, I've checked the "Stream Copy" so the source video stream should be copied to output video container, but I'm still worried about this issue. Is there anybody could confirm this?
I have same question too for copying SWF stream to AVI.
Nope, it shouldn't reconvert. How long does it take when you run it? If several minutes then something is wrong.
You could also use FLV Extract, it will make an avi and mp3 that you can import in Virtualdub. -
Thanks for the confirmation. The source video file size is 13 MB, it only took less than 1 minute to finish the task.Originally Posted by Baldrick
Thanks for the suggestion. Alternative way is to use FLV Input Plugin which no need to import the audio. But the downside is FLV Extract cannot handle SWF. Do you know tool for extracting stream in SWF without decompressing/recompressing? Do you know a tool for copying stream from SWF to AVI besides SUPER?Originally Posted by Baldrick
Btw, I just found out there is a big difference in size of the output AVI from between SUPER and using FLV Input Plugin. The output AVI size from SUPER is 21.6 MB, while the AVI size from FLV Input Plugin is 13.2 MB. Do you know what's the cause of this?
MKV to AVI direct stream copy problem...
By zovx in forum Video ConversionReplies: 26Last Post: 25th May 2011, 09:14 -
SUPER settings for .h264/ac3 to FLV renders unplayable file
By TigerLord in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jan 2011, 19:15 -
Looking for a super fast converter that will handle flv-to-avi
By snafubaby in forum Video ConversionReplies: 2Last Post: 14th Nov 2010, 08:42 -
Using SUPER to convert AVI to FLV; afterwards...how to upload?
By jmcconnell86 in forum Video ConversionReplies: 1Last Post: 13th Jul 2009, 20:48 -
FLV to Avi or MPG, recommended settings?
By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 16:27
