I have been successfully backing up for years using RipIt4Me, then DVDShrink, then burning with DVD Decrypter. I normally just back up the menu and the movie, leaving off the extras. I use Taiyo Yuden DVD-R discs, and burn at 4x.
Recently I've noticed some of my backups freeze for a second or two, every 5 to 10 minutes in various areas of the movie, often moving in frozen steps for up to 5 minutes. The freezing also includes strong pixellating.
I know all of my software is old, and can't be updated.
I guess my problems are to do with the newer copy protection now on discs, and I am very out of touch with current available backup software.
What program(s) should I change to, to solve my problem? Or is there something else I should be doing?
Thanks![]()
Latest DVDFAB Decrypter or run AnyDVD in the background.
https://forum.videohelp.com/topic283172.html -
While your software choices are indeed dated, there are few things to consider.
DVDFab HD decrypter is now the weapon of choice for most ripping, most of the newer protection schemes are not used as often over here. This means that while you are using older software, it still generally works as well now as it did back then.
Changes you might consider would include Imgburn instead of DVD decrypter for burning. Same author, better burner but no ripping.
Cleaning your player. It sounds more like your player may getting old and doesn't like burned media as much any more. Do you see the same issues with these discs in other players ?
Or it could be your burner that is getting past it.
To me it reads more like a hardware issue than a software issue at this stage.Read my blog here.
Thanks for the help.
I think I may have stumbled across the main reason I'm getting intermittent freezing/pixellating.
In desperation I checked that my burner was set to DMA (always has been).
SHOCK, HORROR.
Windows, or something had set my burner to PIO.
And there was a message explaining that I was getting too many erros when set at DMA, so it decided to set the burner to PIO.
I have re-installed the latest drivers for the burner and for the controller, and obviously set the mode back to DMA (Ultra DMA 4 - Ultra66).
I don't know if the "errors" was me trying to rip discs with scratches which did cause lots of errors, or whether it has something to do with the cabling between the burner and the M/B.
The burner is a ASUS DRW-1608 P3S.
I'll also do as you advise, and update my software.
Hopefully this will solve my problems.
Thanks again
Standard Backup DVDs freezing on my new Sony BlueRay BDP-S550
By bribri25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Jan 2009, 14:46 -
Intermittent DVD freezing/skipping (VIDEO_TS?)
By Felix Felicis in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2008, 16:47 -
Please Help! DVD-R disc are freezing/breaking up and pixelating.
By elove in forum MediaReplies: 19Last Post: 19th Sep 2007, 11:02 -
Backup DVD Freezing At End Because Of Size
By medlinwsp2m in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2007, 02:52 -
Old DVD's are pixelating?
By jlburn07 in forum Authoring (DVD)Replies: 2Last Post: 11th Jun 2007, 02:17
