i am converting from an avi to an mpeg using tmpgenc. i am getting an error trying to read the audio part of it. avi2vcd said it could not "decode" the audio.
please help!!
First strip the audio in virtualdub
save audio as wav
after wav is saved open video in tempgen and under audio file open the wav you created then encode -
wtf, I do that, and my audio gets outta sync.... from the mvie in SOME avi files... how Do I fix!!!!
When i convert from avi/divx to mpeg, i allways extract the audio using GraphEdit. I've done this with both PAL and NTSC movies, and i've never gotten sync probs. You need to combine the right filters to make it work. First press "file/render media file". then remove all video filters after "avi splitter". Remove all audio filters after "mpeg layer3 decoder". Add directshow filters "WavDest" and "FileWrite". Press play button and wait. Voila. But if jaywings method don't work i don't se why this one should, but it's worth a try...
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
converting .rm to mpeg, avi using eo video problem!!
By convertme in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 00:37 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34
