This is my motherboard and it only has 2 pci slots the pci slot on the left near the edge of the board has 3 to 4 semi conductors I cannnot add my Radeon 9200 or my old tv tuner card in the slot is there a way that I can fix this problem without short circuting my motherboard ?
Foxconn really doesn't know how to design a motherboard
Wasn't the Radeon 9200 an AGP card? If so, you need an AGP card slot, not PCI, so this motherboard won't support it. My guess is that your old video card is also AGP.
Buy My Books -
You are pretty much out of luck. About your only choice would be to try and bend them out of the way, but they will likely break...and of course void your warranty. I'd simply return it and get a new one.
Google is your Friend -
Looks like the 9200 had both an AGP and PCI version...Originally Posted by gadgetguy
http://ati.amd.com/products/radeon9200/radeon9200/compare.htmlHave a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
check out my setup and let me know the problem
By thedude4242 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2011, 17:20 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 16:54 -
Problem with Projector Setup
By Dimava in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2009, 15:41 -
Motherboard problem
By wan2no in forum ComputerReplies: 5Last Post: 11th Sep 2008, 08:54 -
Pioneer DVR-531H-S Setup Problem
By christopheramos in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th May 2008, 17:43
