hey guys i have a 500gig external,i use it with my philips and my xbox 360,,,both reads fine from it,plays files on it without a hitch,,but now when i plug into pc "my computer" goes into not responding mode for awhile,,then when it does show it it wont access it,,i've unistalled,reinstalled,changed usb drive number,,swapped usb's ,,btw it doesnt work on either computer i own,,i dont understand why the dvd player and xbox has no problems with it,,but my computers wont read it anymore
Something doesn't sound right. Typically, if a device won't work with multiple PC's, I'd suspect the device itself. Since it seems to work with some devices and not others, I'd think it would be one of two things. Either a bad cable, or the drive itself. You may also want to ensure the device was properly "removed" from the PC's.
Google is your Friend -
re-boot the pc, and or uninstall the usb in device manager and re boot
XP service pack 3 also seems to do something to usb functionality on some PC's.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
i have xp on one and vista on the other,,i use the same cable from dvd to pc and xbox,,,so the cable is good,,the pc will see the drive as a basic storage device,,just wont access it
if the hard drive has an on/off switch try that whilst it is connected
Is the drive assigned a drive letter?
Go to Control Panel / Administrative Tools / Computer Management / Disk Management - you should see the HDD listed there, it will also give you the status of the drive. It is likely not properly recognized because of a partition/formating issue and needs to be corrected.Google is your Friend -
i looked it has a letter.But under file system,it says raw,the others say ntfs.should say fat32 instead of raw,,hard to belive a dvd player can this thing and my pc's cant
"RAW" basically means that the PC doesn't recognize how the drive is formatted. The easiest fix, would be to simply partition and format the drive with your PC (of course all of the data will be lost). If you want to try and fix it, give gParted http://gparted-livecd.tuxfamily.org or test disk http://www.cgsecurity.org/wiki/TestDisk a try.
Studio14 HD Ultimate, can't open project files from ext. HDD!!!
By rivrbyte in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 15:49 -
Problem Formatting Ext HDD Fat32 Partition
By Shaky Jake in forum ComputerReplies: 6Last Post: 3rd Jan 2009, 17:27 -
BURNING from Ext HDD USB2.0 VS eSATA ( iso or video_ts )
By orgun in forum DVD RippingReplies: 0Last Post: 13th Oct 2008, 19:22 -
ext HDD hook up to a Philips HTS3440-37
By fdago013 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Aug 2007, 13:11 -
FIREwire HDD, NOT in my computer,update NEW acomdata HDD works great
By theewizard in forum ComputerReplies: 22Last Post: 20th Jul 2007, 02:01
