Using XP sp 3 and I've been getting explorer crashes when left clicking on mpeg files. I can right click and double click on them on them without any problems.
I've tried disbling all third part shell extensions but that didn't work.
This is the event log entry for the crash
When I Google viscommpgdec.dll I get a lot of hits relating to Vista and Windows Live Photo Gallery (which I don't have installed).Faulting application explorer.exe, version 6.0.2900.5512, faulting module viscommpgdec.dll, version 9.0.0.0, fault address 0x00003119.
Isn't it always the way. In a moment of clarity after posting I fixed the problem.
Did a search on my computer for the dll expecting to find it in a Windows folder but found it sitting in a folder for Free Video Converter by Extensoft. No problem I thought, I'll just uninstall the program. Unfortunately this program doesn't have an uninstall routine but I did find a batch file that unregisters it's dll's. Ran it and problem fixed.
Strange thing is I installed this program over a month ago to try it out but the left click problem only started a week ago. -
Explorer can crash when it tries to open a file it doesn't understand and generate a thumbnail for it. But it sounds like you found the cause of the problem.
A temporary fix is sometimes to turn off thumbnails in Folder Options.
And welcome to our forums.
Certain MKV file crashing explorer.exe
By liuzhen in forum Video ConversionReplies: 4Last Post: 27th Jun 2012, 07:32 -
Windows Explorer crashing when trying to rename/play video files over 5GB?
By yatesl in forum Software PlayingReplies: 4Last Post: 18th Dec 2011, 20:19 -
Internet Explorer 8 Keep Crashing
By Squid_uk in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2009, 18:44 -
Windows Explorer Detail View to show MPEG duration?
By dejandr in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2009, 06:36 -
How can you get rid of Internet Explorer?
By video_enthusiast07 in forum ComputerReplies: 8Last Post: 10th Jun 2007, 19:05
