    Nov 2008
    Hi,
    I have DVD Fab and I am looking to use this to extract the AC3 audio from DVD's, can this be done? If so how do I set it up?
    I have used DVD Decrypter in the past which works perfectly if you enable stream processing, however it can't cope with the latest copy protection of films such as 007 Casino Royal.
    What I need is a phyiscal AC3 audio files, rather than the usual empty audio file you get via a standard copy.
    Any help is much appriciated :@)
    Nope. But you can rip the dvd to your hdd and then use pgcdemux to rip out the ac3 audio.
    Or install ANyDVD and use DVD Decrypter as usual.
    Nov 2008
    How do I know which files to open with PgcDemux as the video files has several files?
    Alternatively how do I need to set up AnyDVD to do this?
  4. Hi agtjones,
    If you have "DVDFab Mobile Option", you can extract Audio from DVD.
    1. Select "Generic" in left navigation bar.
    2. Select the title/chapter you want to extract.
    3. Click "Next" and check "Conversion Settings", you can choose "Audio Only".
    4. Choose "geneici.audio.copy" profile in "Device" line, or you can convert audio to MP3/MP4/WAV.
    For detailed guide, please check http://www.dvdfab.com/docs/index.php/Main/DVDToMobileAudioOnly
    Best Regards,
    Fengtao
    DVDFab - Copy DVD and Blu-ray Disc to DVDR, BD-R, MKV and iPad/iPhone/iPod.
    Jan 2014
    Kazakhstan
    Will there be a top box VidOn.me support HEVC? First released hardware HEVC it was MTK Corporation
    - you can put a decoder and teach you to play streaming TV / Video in p2p networks (This will allow abandon cable TV operator) and start playing - free of charge - transfer from the Internet (group system / method torrent)
  6. Member Cornucopia's Avatar
    Hijack much?! Talk about non-sequitur.
    You're also way too early.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Please make a new thread instead.
