I have a dvd that someone decided to remux and put in an extra audio in. I had a look in the audio setup page and the option is not there so looks like they just forced an other track in, should I just use dvdshrink to remove that track and reauthor ?
Is there some reason you can't just leave it there, even if you have no use for it? Even if the new track can't be turned on via the menu, can you get to it by using the remote control? Do you need the space it takes up for something else? Why create work for yourself? Forgive me for being blunt, but your post makes no sense to me.I had a look in the audio setup page and the option is not there so looks like they just forced an other track in, should I just use dvdshrink to remove that track and reauthor ?
Great guide!
....Moving you.
Audio setup? The dvd menu audio page or audio setup page on your dvd player?
Yep you can try dvd shrink to remove it.
Problem with Remuxed MP4 Files
By snowfi6916 in forum Video ConversionReplies: 3Last Post: 17th Feb 2012, 03:21 -
synchronizing video and audio in a remuxed MKS
By wsw70 in forum Video ConversionReplies: 0Last Post: 18th Jul 2011, 07:37 -
Adding menus to a remuxed Blu-Ray
By ITISRAVI in forum Blu-ray RippingReplies: 0Last Post: 17th Nov 2010, 10:27 -
Remuxed mkv using mkvtoolnix leaves file unplayable
By micnolmad in forum Video ConversionReplies: 4Last Post: 10th Jul 2010, 12:33 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 10:05
