Hey guys!
Having a bit of a problem with a video I am trying to import into Sony Vegas Pro 8, when I import the video all that is displayed in the timeline is the audio channel, but when I choose form the options 'open file in player' I get the audio and video playing, I have tried opening the video in Movie Studio but it does the same.
Here are the detail of the clip obtained from GSpot:
Audio
Codec: 0x0011 (DVI ADPCM)
Info: 44100Hz 177 kb/s (1 chnl)
Video
Codec: M4S2
Name: Compliant MPEG-4 v2 Simple Profile
FP/s: 29.970
640 x 480
Is there something I am doing wrong or missing i.e codecs, plugins?
				Results 1 to 14 of 14
	the 8.0c update is on sony's site for download, i'd try that first.
	I have upgrade to 8.0c but unfortunatly I still have the same problem!
	Just seen this topic https://forum.videohelp.com/topic345729.html?highlight=stream%20attributes%20could%20determined
 It seems I have a similar problem but unfortunatly due to the attitude of the original poster it seems he did not get the answer he wanted!
 Could you guys recommend anywhere I can upload the file so as someone may looks at it?
 Also if it helps the file was taken using a casio digi cam.
	if you have a hotmail account, it has shared space. or sites like rapidshare, mediafire, megaupload, or google file sharing for others.
 [edit] or if you can make one under 6mbs it can be attached here.
	Here we go then!
 I have 19 other clips taken with the same camera, some are larger files due to length.
 cimg0696.avi
  MPC won't display video on second monitor.By zeek543 in forum Software PlayingReplies: 4Last Post: 19th Sep 2013, 22:21
  Editing .264 video from mini-cam in Vegas: Vegas won't read videoBy bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 12:35
  Playing Video on display 2 and display 1 goes blackBy sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36
  Formated softsubs won't display as formatted!By aruwin in forum SubtitleReplies: 9Last Post: 24th Nov 2008, 03:58
  TDA won't display video thumbnails after VobeditBy spiritgumm in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2007, 15:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
