Hi
I have a dvr pci card but my pc can not identify the model or the device.
is it possible to find drivers and software to install it, so i can run again my surveillance system?
i do not know the model or manufacturer of the card but i can give you this information:
Xilinx spartan xc2s150
TechWell TW99
EtronTech em637327q-6
s/n 0803ab4700059
and icap1603 rev1.2
the model of the system that it was intalled is digiquard 3008
please help
Xilinx appears to be a chip manufacturer of programmable chips. No help there.
Techwell is a security system manufacturer. This is probably where you want to look: http://www.techwellinc.com/products/products.html I didn't get anywhere with 'TW99' but you might email them with your information. They do list models starting with the 'TW99...' numbers.
Those type of boards can be difficult to find information about or drivers for. They are usually custom made by small companies in China to specifications from the distributor.
In the US, most video type cards also have a FCC number on the underside and that can often be used to locate a manufacturer.
And welcome to our forums.
Thank you fo the reply
i contact them and they reply to me with a link for the drivers and the software i hope i will setup my system again
thnks again for your help
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 20:45 -
PCI Graphics Card
By blueyonder in forum ComputerReplies: 20Last Post: 6th Jun 2009, 10:40 -
why is pci-e card required for pinnacle
By hitenmdesai in forum Newbie / General discussionsReplies: 0Last Post: 29th Aug 2007, 05:51 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
