hm but using Wordpad I can only convert into Unicode, txt and RTF :S
Results 31 to 39 of 39
That's it, save as "Text Document", just keep the extension ".ssa" in the
final filename. This should generate an ANSI-encoded text file, because
the Svenska character-set is ANSI-compliant.
If I open the .ssa in wordpad and then save it as swe.ssa or something and choose ".txt" in the lower panel, ALL 3 swedish characters changes to these I have written before. Let's take it from the beginning once more now only in wordpad!
1) It all start with a .srt file where I cannot see the swedish letter "å" it's instead repleased with ĺ
2) I open this .srt in wordpad and mark one of these ĺ and press CTRL+H to open the "replacement window"
3) In the replace-window I write "å" and press repleace all.
now if I save as txt but with the .srt end all å's is changed into "?" instead whien I close and then open the file.
If I instead save it like Unicode with .srt end all the "å"'s are there when I close-open the file.
Are you sure that these Swedish characters are in ANSI and not Unicode?
4) It's still unpossible to open this kind of Unicode-srt in Subtitle Workshop so I can't create a .ssa at all -
Definitely there is something wrong with your PC.
Better take a long look at the Language and Keyboard settings ---
even though I'm afraid this won't be very helpful.
really oh no!
how could it be my PC is kind of new. maybe it's because I've changed the "NON-Unicode language" to polish from swedish in these language options ...really werid
thanks for writing in my thread DereX888 btw =) sry forgot about youOriginally Posted by DereX888
... first of all I'm not making a DVD but I want to burn in subtitles into an .avi file (and create .avi) using AviRecomp but there seems to be a weird problem with the characters
. But I have now changed all the .srt, .txt .ssa and so on (subtitle files) to open in wordpad isntead of Notepad.
thanks for the info !
cheers
michcio -
Unlikely that the source of your current problems is hardware-related,
if that's what I presume you're thinking.
Probably it's some application
that you have installed recently and that is making Notepad behave as though
it had been infected by the stupid TextPad.
Perhaps reverting the changes
you made in the Control Panel will fix the issues, I really don't know.
Many moons ago, I decided to give a try to an overbloated crapware from
Creative Lies, and it not only prevented WinAmp from playing any type of media,
but also made one of the built-in display fonts of a hex editor be replaced with
a Katakana festival which came from "I-have-no-idea".
Hope you'll find a solution soon. Good-luck!
P.S.: As a "last resource", you could try BabelPad
{ http://www.babelstone.co.uk/Software/BabelPad.html }
HTH.
hate unsolvable problems
I can't think of any software I have resently installed which could affectt Notepad or the carachter encoding in a bad way at all
well if I change back to Swedish in the settning I was talking about...then I'll look on polish subtitles instead because the swedish will be correct always. But can test doing that later and inform you...will also test BabelPad
thanks!
michcio -
Hi I have very strange problem with my polish subtitles. I tried to save them as a .srt (later I tried another format with the same result) and after saving my subtitles are loosing polish charecters. When I'm using Subtitle Workshop I see all polish characters (fonts - letters) but after saving when I open them in Notepad They are not there. I have changed my regian for Poland I changed in windows Character Encoding for Central European (Windows-1250) and nothing changed. Can someone tell me what is my problem because I don't have any idea what's wrong? Thanks in advance !!!!
JKoniak
Matrix Character SubRip
By Anonymous171 in forum SubtitleReplies: 0Last Post: 7th Apr 2012, 20:38 -
MKV subtitle character problem
By ratatouille in forum SubtitleReplies: 1Last Post: 22nd Aug 2011, 05:43 -
dvd subedit turkish character problem
By siddharta in forum SubtitleReplies: 0Last Post: 28th Nov 2009, 21:44 -
question about different OCR (optical character recogni) programs
By jimdagys in forum SubtitleReplies: 3Last Post: 19th Dec 2007, 19:31 -
Need good character generator
By tonynasc in forum EditingReplies: 0Last Post: 24th May 2007, 20:03
and DVD came out fine...
