I converted an avi file that was 2hrs 21 mins and the final DVD output was only 3.10GB.
I know it can be better, but I can't seem to find how to change the bitrate setting. I DID select 4.7GB output - so I want to make use of the remaining space and quality there.
I searched around but did not see any specifics on custom bitrate setting (for version 4 at least).
source > track1 settings >video >re-encode all as below > VBR 2 pass Then adjust your "max bitrate" to 8000 and "bitrate" until the output size bar at the bottom is where you want it......
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 08:05 -
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 13th Jun 2010, 00:13 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 14:06
