I want to send a bunch of movies to my mother who has a DVD Player that plays Divx. However, all these downloaded movies are xvid. Will they play on her player or do I have to convert them all? Thanks for help.
They'll play unless they were encoded using certain settings. These might include GMC, Q-PEL, and maybe Custom Quant Matrices. It might be best if you test them first on a friend's DVD player that also plays AVIs.Will they play on her player or do I have to convert them all?
The following sticky lists encoding options that may or may not be problematic for Divx/Xvid playback on DVD players:
https://forum.videohelp.com/topic352457.html
Note that some of these encoding options are a lot more common used in Xvid encodes. None, some or all of these may be problems on any given DVD players that supports the format (older players most likely will have problems with all of them, newer players may only choke on some of them).
Finally, it's not used a lot, but encoding with a custom encoding matrix can also cause playback problems on some DVD players. If you don't know what that means then don't worry about it. It's not common, but I have seen it. -
and we thought we had problems with Beta and VHS
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
You also might need to remove packed bitstream. Do this with Mpeg4Modifier.
mine plays xvid. it's a portable dvd player with divx sticker on it and it plays all my xvid movies using the usb/memory stick.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Is this DVD Player can play Divx or XviD?
By php111 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 6th Oct 2007, 08:29
